This sounds correctyes, I'm wondering also. I have my output from Isolated Orian-positive going to PV shunt and negative going to negative busbar. Negative busbar is grounded to chassis
Sorry, I noticed that after I made my post (and I corrected this in an edit). Your modified image is correct.
To make things more explicit, the DC system is not supposed to be isolated from chassis ground, but the negative to ground connection is only supposed to happen at a single point. What an isolated DC-DC charger does is split the engines 12V electrical system from the house DC electrical system so that each can be connected to chassis ground without creating multiple ground connections in the same system (a ground loop).
Modern car electronics do not use the chassis ground for a negative return. This causes rust and corrosion in the chassis and weird electrical behavior if the body is damaged and repaired after a collision (Bondo makes for a lousy electrical conductor). The reason why the DC negative is connected to chassis ground is to eliminate static build up on the wiring and electronic equipment and also so that if a wire gets shorted to the chassis it will blow the fuse. You really want to know when your wiring is shorting out.
This is exactly the same reason why AC neutral is connected to the green ground wire at the Circuit Breaker panel. It is a code and a safety violation to have more than one ground to neutral connection in AC electrical wiring. That is precisely one of the conditions that GCFI breakers are supposed to detect and protect you against.
-Edit (to make it clear I modified this post)
And the extra ground connection is not optional when using an isolated converter. You must have the "extra" ground connection since you are not connected to chassis ground by the alternator ground connection. Basically the isolated converter makes it look from a DC standpoint (as measured with an ohm meter) that the two systems are not connected to each other at all. This is generally a good thing to do.
That is exactly correct.I think I have a firm-ish grasp of the benefits of only bonding neutral and ground or negative and ground in one place.
I suppose what I'm struggling with is understanding how the isolated DC-DC actually prevents there from being multiple negative-ground bonds.
But I think it just finally clicked for me (or maybe I'm about to discover I'm still not understanding it correctly. Even if there are multiple negative-ground bonds (at least one on the vehicle electrical side, and one on the house side) and even if bonding both sides of the system to chassis means it is not truly isolated(?), because the internal isolation of the DC-DC charger prevents ground loops.
Is the kindergarten level diagram (now you will be subjected to my drawings ) I'm picturing in my mind accurate-ish on a conceptual level:
Ah, I think that I got it. Isolated DC-DC charger mean that charger isolates ground from alternator/engine battery so that your house electical does not make a loop! Why don't the they just call it an isolating ground DC-DC Charger-LOLAgreed and to make a long story even longer.
In general we don't want to use the vehicle chassis to carry current. Doing so leads to corrosion and weird electrical behavior. To ensure this can't happen we use a negative bus system and only connect that negative bus to chassis ground at a single point.
If you don't have alternator charging, then we are done. However, when we add alternator charging we now have to deal with the fact that the vehicle maker connected their negative to chassis ground in the engine compartment. Our options then are to either disconnect the house negative bus from chassis ground or use an isolated DC-DC charger that breaks the galvanic connection to the alternator DC system. Either solution will work.
If the house system is installed in a trailer and you want to use alternator charging then you must use an isolated DC-DC charger so that the house system can be connected to the trailer's chassis ground without creating a ground loop when connected to the alternator.
I hope I said that clearly. It is more than a bit complicated (I am leaving out lots of techie details that don't usually apply to power systems) and EE's don't always have total clarity on grounding. I took a 3 day seminar from a Dr. Tom Van Doren on this exact subject and I think only half the EE's in the class where really keeping up with him. The rest just pushed their "I Believe" buttons.
Here is a link to the on-line version of the course. It was a lot more expensive to take in person. Yes I am one of the 19,000 engineers who have taken this course.
Isolation is actually a pretty big deal. Isolated power supplies on a PCB often costs twice what a non-isolated power supply does. At higher power levels the cost delta must not be as bad.Ah, I think that I got it. Isolated DC-DC charger mean that charger isolates ground from alternator/engine battery so that your house electical does not make a loop! Why don't the they just call it an isolating ground DC-DC Charger-LOL
I think this would be a sensible replacement. For one you are switching out a decent but no-name component for a quality Victron component, and two you can potentially eliminate the BP-65, so it might wind up being both cheaper and simpler. Do you have a link to the model of DC-DC converter you are looking at, there are some differences (in efficiency and in connectivity between models)
How would I go about getting a qualified person to look over my plan in detail checking compatibility of components, wire sizes, fuse/breaker sizes, connections, busbar sizes, etc?
Reach out to Bay Marine supply, they offer consultations and design review for a reasonable price. They are a marine electrical shop in San Diego area, Justin Cook is their lead tech I think, he is a forum member (@Justin Laureltec) and is quite knowledgeable about Victron products specifically. I believe they charge by the hour, and I recall the rate being semi-reasonable. MarineHowTo would be another option to look into, but might be a bit pricier.Don't get me wrong I'm sure you as well as many other people on this forum are more than qualified but I don't know if anyone is looking at all the details or if they look and comment on things that stand out.
Another resource is Peter Kennedy at PKYS in Annapolis MD. He is a Victron and Blue Sea dealer as well as a certified marine electrician. He has excellent prices from what I can tell.Reach out to Bay Marine supply, they offer consultations and design review for a reasonable price. They are a marine electrical shop in San Diego area, Justin Cook is their lead tech I think, he is a forum member (@Justin Laureltec) and is quite knowledgeable about Victron products specifically. I believe they charge by the hour, and I recall the rate being semi-reasonable. MarineHowTo would be another option to look into, but might be a bit pricier.
thanks!Reach out to Bay Marine supply, they offer consultations and design review for a reasonable price. They are a marine electrical shop in San Diego area, Justin Cook is their lead tech I think, he is a forum member (@Justin Laureltec) and is quite knowledgeable about Victron products specifically. I believe they charge by the hour, and I recall the rate being semi-reasonable. MarineHowTo would be another option to look into, but might be a bit pricier.
Thanks!Another resource is Peter Kennedy at PKYS in Annapolis MD. He is a Victron and Blue Sea dealer as well as a certified marine electrician. He has excellent prices from what I can tell.
I really like his circuit breaker and switch gear panels. Top notch equipment. I was happy with what I ordered from him.
F.Y.I. I am posting updates to my system diagram here if you are interested.
24V Van System Drawing. Get your overripe tomatoes ready!
After months of pontificating, I have finally pulled together the electrical design for my RV conversion. Let me know what you think. This is my first version and I would much rather fix as many problems at the pixels on a screen stage as I can.diysolarforum.com
I have updated my drawing to add battery temperature sensing to the BMV-712. The BMV-712 has a charging disable function to protect against freezing temperatures. The second BMV-712 input can use a thermal probe and it has two methods of controlling external devices. A relay contact closure output, plus the VictronConnect protocol over a VE.Bus port.
The Orion TR Smart Chargers only support a contact closure input for external charge control, so I am going to use the BMV-712 relay output in series with the ignition switch input to the Orion TR.
Both the SmartSolar and the Multiplus VE.Bus support VictronConnect over VE.Bus and I believe the Multiplus has a pass through function for the VE.Bus. If so, I will connect the BMV-712 VE.Bus to the Multiplus first then pass the VE.Bus through to the Smart Solar. In the event this pass through doesn't work, I will use the VE.Bus directl to the Smart Solar and use the contact closure input on the Multiplus to disable charging.
I would like to be able to stop battery charging for the following reasons without the BMS having to get involved:
If I can daisy chain the VE.Bus ports I am hopeful that I can use the BMV-712 to disable discharge based on reaching a minimum state of charge. If not then I will use the low voltage disconnect functions built into the Multiplus and the Smart Solar (I am using the load output of the Smart Solar to power my 24VDC loads). I have an external low voltage disconnect circuit that is used for 12V (non-critical) loads and I will configure this to disconnect at a high enough voltage level that I am sure I am not over discharge the battery.
- Over Temperature Alarm
- Freezing Temperature Alarm
- Battery has reached a programmed state of charge
The BMS will basically only be used to protect against cell imbalances and as a last backstop in event of a charging or discharging malfunction.
I am still researching all of this. If it turns out I need the Cerbo GX to do what I want, I will add it, but for now it is looking like I can do what I want with just the the BMV-712 wired to the other Victron devices.
Nice, interesting idea of filter and surge protection at shore power entry. Don't believe that I've seen this on other designs. Also like the 24v appliance-no sense in converting from 24v to 12v when you can buy 24v appliances.F.Y.I. I am posting updates to my system diagram here if you are interested.
Looks like one of wires not connectedI decided to go with VictronMulti Plus 24/3000/70-50. It did increase cost by $650 but over all quality and simplicity of use with Electrodacus makes it worth it. I attached my latest diagram with changes. Now I just need to go through with a fine tooth comb and make sure all wires, fuses, and breakers are sized correctly. Make sure everything is connected correctly, etc.
I certainly appreciate everyones help on this forum; it's been great. question-How would I go about getting a qualified person to look over my plan in detail checking compatibility of components, wire sizes, fuse/breaker sizes, connections, busbar sizes, etc?
I decided to add 24v connections for appliances as you did. It was not as straight forward as I first thought since SBMS0 needs to be able to turn them on/off when batteries are discharged to certain level. For this reason I added Victron Energy Battery Protect 12/24-Volt 65 amp and run EXTI5 through 4-Channel Optocoupler. I hope this makes sensesF.Y.I. I am posting updates to my system diagram here if you are interested.
got it!Looks like one of wires not connected
