I've figured out how you can make "zero export" instead do "zero export except for your approved 3kW NEM system".
Also, "zero export in excess of 3kW"
Yeah, the key is how to set the AC current limit so it’s not kicking-in until exceeding 3kW.
Another alternative is to have all of my daytime consumption, primarily my 5 fridges/freezers, wired through the same subpanel. Then I could just feed the new Microinverter into than panel and only turn on the charger whenever that subpanel starts to export to the main panel.
That, combined with a timer on the charger so it’s only available during the peak hours of the day, get me to 95% of where I’m trying to go...
Just a clamp meter wired into a comparator driving a relay could solve the issue with no Arduino/smarts needed...
Can you use multiple SUN GTIL as a team to deliver multi-kW and still limit export?
See, that is the thing. The GTILs are fantastic for replacing consumption with battery power, but they don’t represent a load at all (except the battery),
So what I want is a GTIL-like load, which is a battery charger combined with a clamp sensor. An ideal charger would calibrate it’s consumption to offset export (like the GTIL calibrates generation to offset consumption), but I haven’t found any variable-power chargers and designing one goes way outside my competence level (or interest, frankly).
Since I’ll know the maximum power generation as well as the consumption of all the fridges, configuring a properly-sized charger to turn on as a dump-load to only turn on when all fridges are off sounds like the most straightforward solution...
