So i have a gas generator and have a plug to my outside circuit box to power home when power is out.
I know you have to kick main breaker to use generator so as not to backfeed to the line.
I've seen some inverters will fry if connected to a home circuit breaker due to ground and neutral being tied together. Is there a way to test your inverter to see if safe for powering panel when power out instead of dragging out the generator
My setup will be giandel 3000w purse sine and a 24v battery bank.
