I know I am asking a lot of questions regarding grounding. I have a ground mounted solar array. I am running my PV cables through the attic. I know I need to have the PV cables and metal conduit once it enters the attic. I am running a separate EGC from the solar panels through the conduit to ground within the inverter. I am not using the EMT as an EGC. Do I need to separately ground the EMT conduit. If so, can I ground within a junction box and run that ground wire to a ground in the inverter. Or do I actually have to ground both ends of this EMT run even though I am not using it as an EGC. The EMT will come from the attic into the garage and connect to a plastic housing for the PV disconnect. Out of the PV disconnect will be flexible non-metallic conduit to the inverter.
Thanks in advance for any responses
Mike
Mike
