filippomasoni
What do you think is a good lightweight DIY design for a battery enclose (mine will be an 8S EVE LF280K configuration) for a truck camper build, that prioritizes ventilation to keep the temperatures cool during trips in warm areas?
I've read so much on this forum and elsewhere about compression and I perfectly understand it, but I think temperature control is as much or more important but nobody talks about it. The EVE LF280K spec sheet for example gives a 6000 cycles life at 25°C with compression and 2500 cycles at 45°C under the same compression.
In a moving vehicle, I definitely need a rigid enclosure that keeps the cells from moving around and the classic threaded rod and plywood is a very effective, simple, and lightweight option since there are fewer sides of plywood than a box, but doesn't allow airflow between the cells. I was thinking of putting alveolar pvc panels between the cells for improved airflow of each cell but I'll lose the compression and won't have a rigid block of cells.
Will a fan blowing air over the terminals (which are probably going to be the warmest spot and also probably thermally conductive to the inside as well) be enough?
What are your thoughts?
