Robkh
I am getting installation of an Endless Pool - I am in Phoenix, AZ.
Energy need estimate from the company:
1. Water Quality System - 1.0 hp circulation pump and 4kW electric heater. Assume the filtration cycles are going for 6 hrs/day and heating for 4 hrs/day (of those six):
3. Automatic retractable cover energy needs <1kW for ~20 seconds at a time to open/close, and the cover pump significantly less than that, because only when rain accumulates.
Total consumption in a high use application ~35 kWh/day.
I believe a 5000 watt solar array can deliver 30 kWh/day and more may be needed. What battery size does anyone recommend?
If I swim in the Winter during the day, the solar array may be enough but my concern is using the pool at night in the Winter, when the sun is down and I need to run this off battery. This will be an off grid system.
Thanks for you input
- 1.0 hp circulation pump (~5.5 A @ 220 V = 1.2 kW) running 6 hrs/day = ~7 kWh/day
- 4kW Heater for 4 hrs/day = ~16 kWh/day mostly in Winter months
- Assume the other items tied to the controller, like keypad functions – including the timed filtration cycle control, and LED lights maybe ~1 kWh/day
