I decided to do an energy audit to see what the power requirements would be for some basic items. I used a Kill A Watt and carefully measured everything.
So far so good. Then I put the power usage in watts, estimated hours, estimated inverter efficiency and size battery in the calculations.
At this point, my mind turned to mush. I will be using a 24v battery.
So, at the risk of sounding like I have never seen a calculation I am asking for advice. Please let me know if I am completely missing it...
Determine Amps (or watts if going that route). If memory serves me correctly: Watts = Amps x Volts.
If I measure watts in AC, then if using a 24v battery, would I multiply AC watts x 5 (120/24)? to determine DC watts?
If this is correct, then I would take this number and divide by 24 to get amps.
For example: Something uses 60 watts.
Multiply by 120/24 = 5
Equals 300 watts d/c
Divide watts by volts to get amps 300/24=12.5 amps DC. Then if an inverter is 85% efficient 12.5/.85 = 14.7 battery amps required
Am I totally missing this???
