Energy audit question: Shallow Well Jet Pump
rjpear
Hi Folks. In starting an energy audit i started with the most important (and problematic ) part of my needs..and that is my water well pump. It is a Shallow Well Jet Pump with the following Specs: 115/230v 3/4hp 8.0/4.0 Amps ..per the label. How would you calculate the pumps needs if it is generally random usage for 30 seconds or so? It is part of a pressure tank system so only kicks on when the pressure is dropped past a certain level.
Thanks..
rjpear
Heh... I guess "it depends" is not a great answer. Lets say 2x an hour on average. I figure after 10 PM it may kick on only 1 or 2 times all night/AM due to no usage.
MisterSandals
Participation Medalist
Lets do some math!
I will go with runs 30 per day. Thats 15 minutes.
.25 h x 120V x 8A = 240Wh per day
For a 24V bank thats 240Wh / 25.6V = 9.37Ah
The tricky bit will be the surge current which can be 10x the 8A run current.
rjpear
Ok..thanks.. so I had a "light bulb" moment when looking at your math. Since I am at 120V I have to use the Higher Amps (8) but if it was run at 220 then would it only use 4 amps? And does this kinda play into the more efficiency of a 48 volt vs 24 volt system.?
Math can be fun! ;-)
Northernchateau
Supervstech
Administrator
Staff member
Moderator
Yes, lower amps, same watts though. Startup watts are still 10 times running watts, so 2500W to start, 240 to run…
MisterSandals
The power use is pretty much the same, especially when just doing the math (real world has to be different)
4A x 240V = 960W
8A x 120V = 960W
Lets say you have 16 100Ah LiFePO4 cells at 3.2V
24V battery bank (either 2P8S or 8S2P) = 16 x 3.2V x 100Ah = 5120Wh
48v battery (16S) = 16 x 3.2V x 100Ah = 5120Wh
MisterSandals
Or how you might be expecting to see the numbers:
Also assuming your battery bank is made up of 16 3.2V 100Ah LiFePO4 cells...
And will use 25.6V for the "24V battery" since its correct (8 x 3.2V):
25.6V x 200Ah = 5120Wh
And will use 51.2V for the "48V battery" since its correct (16 x 3.2V):
51.2V x 100Ah = 5120Wh
sunshine
Maybe a energy audit should look at the efficiency (power & labor) of shallow well jet pumps compared to submersibles.
From my farm experience, 20 - 30ft down , the arrival of submersibles meant the end of the jets.
We also realised that pumping into a overhead tank for a few hours with a smaller pump was a lot better than constantly stop starting a larger pump and also avoided the starting requirements needed for larger pumps.
The arrival of cheap pumps from China made the decision easier!
rjpear
I agree..but I don't have access to the well head at this point (under a Cement foundation of an addition). So it's a new WELL and then the new pumps. Plus the Jet is noisy!
