Enphase IQ8-planning a system
Bluedog225
Texas
Good morning,
I appreciate all the good information available here. I‘ve been waiting for the IQ8 to begin detailed planning and purchasing equipment. It looks like the IQ8 lineup is at long last going to be available next year. I’d like to get down to actually drawing out a system with specific components and prices.
I will be off grid. No looking back. My array will cover 600 square feet of flat roof. At whatever wattage/price makes sense at the time of purchase. I’m very flexible and my energy needs will be adequately covered even with lower wattage panels. In the neighborhood of 12kw. There may be a ground array later more oriented towards late afternoon sun.
I’ll probably purchase a non-Enphase LiFePo battery bank due to budget (e.g. Fortress) or something similar.
Does anyone have an understanding of the variety of IQ8 options? I started trying to dig into the specs of each model and it occurred to me that there might be a something published that explained the differences.
IQ8, IQ8+, IQ8M, IQ8A, IQ8H, IQ8—208V
Also, I’m a little confused by the type of panel the IQ8 states that it is “optimized” for. That is, “high-powered 60-cell/120 half-cell and 72-cell and 144 half-cell modules.” What does that mean in terms of actual panels. Anything 60/120 or 72/144? Or some minimum wattage or voltage?
My thought was to start with the panels and IQ8 so I can pin down my amps, volts, and watts. This will inform my choice of charger/inverter.
Any input appreciated.
Make sure it's compatible, the IQ8s need to know to throttle back when the battery is full. See Incrementally Adding AC Batteries.
...Also, I’m a little confused by the type of panel the IQ8 states that it is “optimized” for. That is, “high-powered 60-cell/120 half-cell and 72-cell and 144 half-cell modules.” What does that mean in terms of actual panels. Anything 60/120 or 72/144? Or some minimum wattage or voltage?...
If you look at the datasheet I think the two important characteristics are matching voltage and watt ranges. For example, from this we know the IQ8PLUS-72-2-US can handle 235 – 440 watts from 30 / 58 volts. So, it would be a bad match for a 62V 400W panel.
Dang. Thanks for the link. Using a different battery was definitely part of the plan.
I’m hung up on a couple of issues.
1. buy/build batteries-leaning towards buy.
2. Which inverter/charger system
3. How worried I need to be about communications.
I’m hoping to see a few system layouts that incorporate the IQ8 with other components so I can learn/evaluate.
Once I can pin down the equipment, I’m ready to roll. Hoping for getting it installed prior to the summer heat.
Entirely off-grid.
IQ8 AC coupled micro-inverter.
Any particular reason for AC coupling and for microinverter when off-grid?
I like AC coupling, but do it with string inverter.
The key to an off-grid system is the battery inverter.
Something about IQ8 and off-grid or battery systems, but I think battery inverter is still a separate box.
And working with a generator probably looks like a grid-backup system with relay to disconnect.
What would the whole setup cost you? How may kW?
If using IQ8, what is its wattage? If less than PV panel, it'll sometimes clip, so you get less out of your 600 square foot area.
My deal is, I want to minimize high voltage DC. I’ve put a ton of time and money and blood and sweat into my cabin. I’m just more comfortable with AC safety systems.
I’ve got two options. I can set up a traditional DIY station in my shipping container with panels, DIY batteries, a string inverter and run 120 or 240 to the cabin. That whole setup seems riskier but it’s just the shipping container. Not the end of the world if something goes wrong.
Or I can put the panels on the cabin roof. Which would be absolutely brilliant for security and additional shading in the 110F texas sun. With IQ8s and run a traditional AC system. Probably with rack batteries.
I had this notion that I could use the IQ8s for AC, have a cheaper than enphase battery inverter, and have cheaper than enphase batteries.
The utility wants roughly $25,000 to run electric to my place. And an 30’ cleared easement which would suck.
I’m hung up a little on whether I can use the IQ8s, some suitable battery inverter, and 48V rack batteries and make all this work. The communications requirements are unclear to me as are the micro-grid requirements of the IQ8s. They may be related.
I am under the impression that going 100% Enphase is going to be much more expensive.
I’ve learned a lot over the last 6 months or so hanging out here but still have a ways to go.
Edit-and thanks for the link!
The high voltage DC of a string inverter could present some risks.
Shock hazard? Never touch it. Open switch to interrupt current, unplug MC cables or remove touch-safe fuses before working on wiring.
Arc, which could start fire. A 3000W, 480 Voc series string could draw a large arc and ignite something. Arc-fault is typical in GT PV inverters. That opens the circuit at inverter. Multiple faults in string could still sustain arc. Rapid Shutdown, which isolates circuit between each PV panel, would likely provide additional protection. So long as inverter stops sending keep-alive signal. With RSD, cost advantage over microinverter is gone.
So yes, that could have some risks.
Low voltage DC would be higher current, also fire risks.
So I can see how micro inverter might be better for fire safety.
The following shows AC coupled system with GT PV inverter, and grid-forming battery inverter.
Not shown is a relay to disconnect loads but keep AC going to GT PV inverters when battery is low, needed to recharge.
Alternative is DC coupled. An SCC with about 100V from each string of PV panels (and fuses or breakers per string). That would be like any traditional off-grid system.
Consider what motor loads you may have. They require sufficient surge from battery inverter.
This inverter (Sunny Island) works with FLA, AGM, or various lithium batteries having compatible BMS. Commercial ones are expensive, but REC is one BMS available for DIY batteries. Sunny Island isn't cheap, but there are liquidation sales on eBay, and Midnight sells a bundle with pre-wired panels (DC SCC optional). Compared to Enphase, may well be less expensive.
Some microinverters support frequency-watts (can AC couple to a grid-forming battery inverter that does frequency shift.) Don't need to wait for IQ8 for that, some but not all earlier models work.
You can then use a different brand battery inverter, with whatever batteries it supports. I suggest Sunny Island, but there are several other brands. You may be able to get new old stock microinverters and battery inverters at a discount.
I'm just getting started, but seems to me that an easy way to go is simply follow Enphase's product line. I learned a lot watching this:
(click on WATCH ON YOUTUBE)
and this
and this
Tables in the first two vids (near the end of each) which shows what you need to buy in order to have an Enphase system that does what you want. Panels and Racking could be whomever, but the rest appears to be all Enphase.
They should just start opening up retail stores!
You must be a "fully" certified Enphase storage installer, including attending a hands-on training class far from home, in order to install AND "turn-on" an Enphase battery or Sunlight Backup system. The problem with this plan is that the Enphase battery backup system is enormously expensive for such a tiny cabin. 10kWh from EG4 is $3000, from Enphase it's $7500 wholesale, $10,000 retail installed. If you want to DIY and have time and money to burn, go right ahead. It's great for a big California home where energy rates are very high, but for a cabin in the woods, not so much. I think they designed the IQ8 installation to be this way intentionally to avoid DIYers using IQ8's off-grid without their control. A Cell modem IS a requirement, as is wifi to make it work, and a continuous internet connection is required or the warranty is void. You can't even activate the IQ8 inverters without their authorization. Believe me, I tried.
Yeah. Enphase seems to hate diy’ers. I steer people away from the company when I can.
Maybe AP systems.
Maybe AP systems.
I'm going with Hoymiles and I'm going to test them out ASAP. Higher power with 350W, 700W Dual, and 1500W Quad microinverters, Put 4 x 1500 on a 30A branch circuit with their pre-made cables. I've got my costs down to $1/W with roof racking. It's amazing. As far as I can tell, they are pretty DIY-friendly. Their training videos are online, and their DTU is not required to make the inverters work. Just connect AC and panels and they work. No-fuss. There is even an export limit capability when using the DTU and a Meter, but I'm not sure if this is only for 3-phase utility operation, or if it can be used to make them compatible with a microgrid. I'll get back to y'all later this week. I'm looking for DIY volunteers to get hooked up for just the cost + TSO so we can test these out.
Maybe AP systems.
I have used the AP Systems QS1 quad inverter, works good except it doesn't AC couple nicely. It doesn't throttle back smoothly like the IQ series micros.
I am an Enphase installer and the IQ8 isn't really setup to make a DIY setup. There are micro's on the panels to turn Solar DC to ac and then a whole additional set of micros set to change AC to DC to charge the batteries and then that same set will convert the DC back to AC for backup.
Well, Did you ever get your system?
Project Solar has good DIY price(s) for systems (IMHO.)
I am getting a full system with batteries and from an authorized installer..($$$) but I know full well that I can "plug in" a separate, battery powered inverter output into the Generator input as a means to provide that as a source. The inverter AC load for the battery charger would merely be a load breaker for the main panel. Sure an extra loop of circuit losses is built in, but that is only in loss of grid conditions...
I have thoroughly tested the HM-350NT and HM-700NT in an AC-coupled system with (10) Enphase IQ8Plus and an IQ Bat 3T. They sometimes do not transfer smoothly when the power fails, the Enphase system has a frequency shift that is intended to kick other inverters off the microgrid. However, once the Enphase microgrid is working, the Hoymiles microinverters can be restarted and they couple nicely, and tend to provide way more power than an IQ8Plus. They worked well during a power outage on the coldest night of the year, by connecting (2) HM-350NT's to a 48V, 7.5kWh battery, utilizing a current limiting board of my own design. I had this pair of micros running in parallel with my IQ Battery 3T. The 3T was providing a stable microgrid, but only a small fraction of the total load.
I am also using a WattNode meter to control my Hoymiles micros for zero-export, and this works well too, even when it was in parallel with the microgrid.
