Red Squirrel
- Jan 1, 2020
- 110
I recently converted my system from 12v to 24v by stringing 4 6v golf cart batteries in series. Got everything wired up and it seems to work but the battery warning is flashing on the unit. Manual indicates it's over voltage condition. From my understanding this model is auto sensing, is it? Everything I read seems to indicate I need to buy a separate controller or use an app... I really hope that's not the case.
Anyone know how I can go about setting the voltage? I played around with the settings but I don't really see much I can do other than change battery from flooded, gel or lithium. I have it set to flooded.
My solar panels are also setup as a 24 volt nominal system so I will have to see if I need to switch that, but I think it should be fine.
