Vigilant24
- Aug 23, 2022
- 119
It seems that many folks here are having trouble with an EPEVER charge controller. These problems can include the SCC "getting stuck" after cloud/shade passage and staying at low voltage or wattage without trying to recompute a better maximum power point when the sun returns. Other users have trouble getting their Epever to charge the battery pack at proper voltage, etc. In many cases these issues occur with Epever controllers used in parallel, and often with LiPo4 batteries or other batteries with a BMS. It's difficult to figure out exactly what might be causing the problems. I understand that there >could< be thousands of happy, satisfied Epever users for each unhappy post, but the number of grumpy folks is not small just based on the posts here.
Here's my question: I am putting together a very basic, old-school system: Four 100W panels, a SCC, and 12V flooded lead acid battery pack (two 12V 100AH batteries in parallel). The panels (approx 20Voc and 5 amp max) can be wired in parallel or 2S2P, either way could work fine. With this simple system, am I likely to experience the same woes that these other folks are having if I go with an Epever 3210AN or 4210AN (plus an MT-50 doohicky)? I'm hoping that the "old style" FLA chemistry is what the Epevers were designed around, that the lack of a BMS eliminates one variable, and that the use of just one charge controller also eliminates some possible conflicts.
Thanks for any input.
