Lady Rover
- Mar 21, 2021
- 3
We have 3x Trina Solar 400W Vertex panels. Each has its own dedicated Epever 4210an Mppt 40A charge controller.
All controllers are wired to the Lifepo4 battery and the displays work.
Two of them charge properly and show the solar panel module in the display.
The third one does display night mode and no input voltage from the PV.
We did measure the panel wiring directly before it goes into the Epever, it shows 38v (+- are correct too!).
We cover the panel up to stop voltage. Than we connect the wires on the Epever and remove the panel cover.
The panel is definetly producing power, but the cable which we checked above shows 0V over the terminals at the Epever input.
Fuses in the Epever are OK.
Any thoughts?
Thank you!
Any thoughts?
Thank you!
