I have 3 x
Revo II (Sorotec)
Like most hybrids, they where LOUD.
Now silent
I placed 2* 140mm stacked at the top (going to change that to 2 side by side)And 3* 120mm down.
The 3* 120 are always spinning, and being fed by 3 LiFePO4 cells.
At 1 watt on +/- 10v that won't drain the battery cells to make it go imbalanced...
Those are case fans "phantek".
Intended to provide light airflow without noise
The 140 are also
phantek, who I will replace one of the 2 with
the silent wing 3.
The 140's are controlled by the hybrid.
Phantek use 0.22A at 12v
Be quiet Silent wings 3 only 0.08A!!
The silent wings 3 is better to push or pull in restrictive environment
(Like heatsinks or radiators)
For the techies : air pressure @140mm= 2.16 H20
and 3.27 for the 120mm
Price wise.. huge difference.
I paid 169 THB ( $6 )for the phantek and 720 THB ( $24) for the silent wings.
Both have liquid baring, Silent wings 3 is rated for 300.000 hours or about 35 years continuous useage.
If they where not that expensive o would use them for all...
Now each Revo II gets one 140 and one 120mm
SW3
And one 140 + 2* 120
phantek
To keep it simple, I took out the 2 bottom fans, and made more room
(Not sure if that was really nesececery, probably just could've kept the original holes) and made a duct for the 120mm fans.
At the top I made opening to pull out the air.
For sure, it does need some cleaning and make it look more nice.
My original idea was to use Delta's.
(Aka server fans)
While one 120 mm can get more airflow at full speed then all 5 others combined.
Like the 80mm type...
Like yet engine taking off
Even at lower speeds.
I've done some "dB" readings withy phone
At one meter distance 56 "points" where clicking the side button for screenshot give 59 "points"
To give impression of the current noise level
I do need to replace already 2 of the 120 phantek. :-(
Not their fault!!
I feed it at first with ac-dc converter and didn't measure the output voltage...
It was +14v...
Au.. lesson learned.. always measure!!!
I played around with the speed/ voltage (so up over 14v) to see the performance gain or loose including dust filter..
Don't use the dust filter type you see on the lower left. Way to restrtive.
At full speed it worked quite nice..
That was 14v.. for weeks.
Even liquid baring can't handle that.
As they need to be replaced, the first 120 and first 140 are going to be SW3.
(I started to buy 2* 140 SW3 to compare them with the 140 phantek, as I have them, better use it
Sure.. inverters aren't computers
And casing is different.
Still the same basics apply.
For more information
Overclock . Net
To learn all about air pressure and how/why it's important.
Also what fans are best / good to use.
Air pressure is key in this situation
Loads of restrictions.
Sadly, most higher pressure fans are small and high rpm = lots of noise.
Golden middle is 120 SW3, with a solid 3.72.
Why use the 140 mm??
Looking back that is not needed.
Probably one 120 push and one 120 pull would do the trick.
I've built a lot of silent computers, and when you need to remove a lot of heat, you can create enough airflow in 2 ways:
High speed (loud)
More fans at low speed
Energy consumption stays about the same.
Initial costs are higher, you need to buy more.
Lifetime increase a lot, running at lower speeds.
If you can't have the budget for outback...
You need to hack
