Aussie Collie
- Dec 18, 2021
- 27
I've just connected my 5415an controller to my two 12v, 100ah lithium batteries in series.
I have the ble-01 connected and I'm going through the battery settings.
So far I have these settings. Some are default, some I have put in:
Boost duration(m) 120 (default)
Equalise duration 0
Temp. Comp. Co-efficient 0
Over Voltage Disconnect 31.2 (default)
Over Voltage Reconnect 29.4 (default)
Equalise Charging Volt. 28.4
Boost Charging Volt. 28.4
Float Charging Volt. 27.2
Boost Recon. Charge Volt. 26.4 (default)
Charging Limit Voltage 29.2 (default)
Discharging Limit Volt. 21.2 (default)
Low Volt. Disconnect 22.2 (default)
Low Volt. Reconnect 25.6 (default)
Under Volt. Warning 24.0 (default)
Under Volt. Warning Reco. 25.6 (default)
Could somebody please tell me if any of these settings need changing, which ones and what to?
Equalise duration 0
