Hi, I have a Epever Tracer BP Charge Controller that I am using to charge my newish 24v LiFEPo4 battery bank.
Previously, the same controller and panel array were used to charge a 12v AGM bank for years without issue. I connect to the charge controller via the bluetooth module and the current EPever Pair android app.
I have gone through the various posts on this forum setting out the lithium battery settings for to be used with the EPever charge controllers.
However, no matter what charge settings I input, it seems that the charge mode is shown to be as "Promote" and the charge current is held under 0.1v. In a recent example, my solar array voltage is at 77.09V, the battery voltage is at 26.59V and the charge current is only 0.07A. This was after the battery had been used where the voltage dropped to 24.23v under load. I think my boost voltage at that instance was 28.6v.
Initially, I thought the lithium batteries were just super efficient and the batteries were getting recharged in the time between they got used and when I checked such that by the time I checked, they were already being float charged. However, that went out the window when after about a month, the batteries showed a low voltage and had to be manually recharged with a wall charger. After being recharged, the batteries appeared to be ok and would still hold a charge and support a load.
I have tried swapping out the charge controller (I have a spare) but to no avail. What is the EPever "Promote" mode? Do I have a setting issue, an issue with my solar array or does the charge controller just not support 24v batteries despite its claimed capabilities?
Thank you so much for helping!
