Deltron
- Feb 17, 2021
- 24
I noticed the time it did charge the volts went up to the low 20s. That said Currently the sun is perfect and it’s still 13.8. And when I covered the panels and disconnect and reconnect the battery then uncover the panels they hit like 16 volts and drop back to 14.I think the solar voltage “head room” needs to be several (like 5v) higher than the charge voltage. It’s possible that your SCC is waiting for higher voltage that it needs. Is there an input voltage range in the spec?
Is there a way to increase the voltage of your array by putting panels in series or something?
Sorry I have not read the entire thread, just the last 6 or 8 posts...(mia culpa)
What do you mean by input voltage? I currently have the boost reconnect set to 13.2 but the battery is now at 12.9 and it still won’t kick the boost back on. The panels and my solar charge controller have been working great for 3 years of daily use now so I don’t think my panels wiring set up is the problem. Thank you for the reply. I am wondering if somehow my solar charge controller and the battery bms are working against each other
