I have a epever up-hi 3000 hm 10022 hybrid inverter. It works just fine, doing its thing.. but some settings I just dont get right..
"Stop the mains chargings voltage" and " restore the mains charging voltage" settings. I asked the support, thay just said its for start and stop of the charging fram the generator. But what should de settings be?
q nr 2;
"Dry contact ON voltage" and "dry contact OFF voltage" , this is a relay that can be used for remote starting a generator. I'm going to use this for one more active balancer .. a test project.. i want the balancer to turn on at 28.3v , then stay on as long the voltage is over 28.3. If the voltage goes under 28.3v, i want it to turn off.. so.. what is the settings for the relay?
"Dry contact on " set at 28.3, thats ok, but when should it close?
q nr 2;
