AK_Offgrid
- Jun 20, 2020
- 13
Good day - hope everyone is doing well.
Looking to upgrade my existing system. Current system: 6x100w mono 12v PVs, 1 EPEver MPPT 40A controller, 1 Trace 1512 inverter/charger, 3xConcord AGM 100Ah batts in parallel. Used in a off-grid cabin year round. Use a 3500w gene for backup/filler when needed.
My batts are aging (10+ years) and so I am going to replace them (with luck before they take matters in their own hands). I plan on moving to LiFePO4's, probably 8 of the Fortune 100Ahs, maybe 8 XCell 176Ah. Either way it would 8s1p.
For a controller (the first thing to be replaced) I would like to get an integrated Solar Charge Controller, Inverter/Charger. I see the unit Will favors and that is not a bad option although I am fond of the EPEver controllers. I have used several of the Tracer MPPT units and like them. Doing some research I see EPEver has an all in one under the U Power line. The U Power line appears to be only 220/230v at this time.
Has anyone heard anything from EPEver about releasing a U Power in 110v?
Thoughts on the MPP Solar all in one?
Other options for the all in one?
Thank you for your time.
