Epoch V1 with V2 460ah marine
Jon Hood
Fort Myers, Fl,
Hi all!,
I have had an Epoch 460ah marine battery in my 5th wheel since December 2024.
I am wanting to increase my system and add monitoring (Victron) devices.
My issue is that the V1 460’s are no longer available and the V2 460’s:
1. Have a different BMS
2. Do not communicate with each other.
3. Have different charging parameters.
So, does has anyone ran the V1 and V2 together in parallel? Can this work?
Is so what are we the cons of this.
I really don’t want to have to buy 2 V2’s and have no use for the V1!
Any info or recommendations would be greatly appreciated!
TIA
Ok - I get the parallel. Define balanced? I’m a newb.
A couple ways:
1) Both batteries to bus bars with similar length cables.
2) Batteries connected + to +, - to -. Load/charge cables connected one to each battery (not charging or drawing from one "end" of the pair).
If you're looking to learn why this is important, read the first 4 posts in this thread:
A couple ways:
Thank you!
Anxious to see if Epoch corrects itself and Will likes them again. I was just going to purchase 4 batteries :(
My battery has been successfully unbricked if that means anything.
I still think there's better options.
