I just purchased/installed 3 100AH LifePO4 batteries (SOK). They are hooked up to 320 watts solar and I'm using a Samlex Solar Charge Controller (Model scc-30ab). I reached out to Samlex to get input from them, essentially the charger works fine but one catch, it won't go into bulk/absorption unless the batteries fall below 12.4 volts for one hour. 12.4 volts for these batteries is quite low (~10%). So my thought if they get down near that SOC, is there any harm forcing equalization from the charge controller which will increase the charging voltage to 14.4 for 2 hours. I wouldn't do it regularly, just when batteries get low and can use the charge.
Here is the setting I'm using now on the charge controller, with equalization mode off so it can only be manually triggered. I reached out to Min at SOK who said no issues but curious if others have different opinions.
Thanks!
Thanks!
