Let us know when you find out, I've been curious about these cells for a while.My main concern now is simply how good the ETCs are given I'll be seeing them soon lol
Batteries are onshore - I will have to pay customs/GST though as customs considers 2 shipments to different addresses as part shipment of bulk order so I should have been told to use a different name and work address and it would've been fine maybe.
Signed paperwork, process has started, see how much extra I am charged.
Fees were a bit over $330, the bastards lol, treated as 1 shipment for total value but charged twice for handling/logistics because it's actually 2. Tried to cheat the system, got shafted instead lol Oh well, live and learn.
Ordered the 150A JK Smart BMS with 2A Active Balancer, was a bit under $270 delivered. was put off by the inconsistency of the Daly. The Heltec/JK seem to be very stable software/BMS wise.
Start to think about a battery box I guess.
The lot, customs, GST, agent fees.
$330 total for both shipments.
When do you expect the cells to be delivered? Curious since I've the ETC 206 Ah cells. They are doing well.Paid, move on with life
Do the screws fit in the batteries? If yes, it will be no problem for the current, surface contact will only be bigger. But maybe it is a good idea to run studs since you use the whole thread in the battery that way. Use a torque wrench in order to avoid damaging the thread.What the heck are these puny screws and threads?
I assumed we'd see M6 thread at least, these look like M4?
I was going to run studs but Is it even safe to push 100amp plus through an M4 stud?
Photo comparison is next to what I'm pretty sure is an M6 bolt.
EDIT: I've just realised I've completely over looked that the terminal surface area on to the bus bar is more critical than the stud size, but I still wish they had at least M6 stud size.
