Within the MB30 ''datasheet' which justgary posted for you, Chapter 4 'Application Conditions' contains 12 sections (4.1, 4.2 4.3, etc) which the customer's usage must maintain for the product, used within a customer's "battery pack", during EVE's warranty lifespan.I tried to find it again... perhaps im confused
These requirements are laid out for EVE's largest direct customers - builders of automotive energy packs, and a few builders of large storage facility units. Hardly anyone here is a direct customer of EVE, and the warranty does not apply to third-party customers like us (typically buying only a couple dozen cells from a secondary "reseller").
The compression requirement is section 4.6, showing the required values within Table 13. It specifies that a "pack" should be designed to apply 3000 Newtons minimum, 7000 Newtons maximum over the life of the pack. (justgary converted to PSI for you, correctly, at 12-28 PSI on large faces of these cells. That' minimum is a bit under 700 lbs of force at sea level.)
The datasheet includes that if excessive compression reaches 10,0000 Netwons for only an instant, will likely cause permanent damage to the terminal post assemblies (the anode "rod" and the cathodic plates), or blow out the cell (along the corner edges, or within the surfaces of the smaller "sides", or the "top" or "bottom".
In designing a pack to meet EVE's specification, the tendency for the cells to swell or shrink in thickness must be addressed. Gary's sheet for the MB30 provides only the rules for the test, without providing any "formula" for the pack designer to estimate the pressure changes which will occur within a proposed "pack assembly" under the varying SOC and temperature conditions which that pack is expected to experience during its working lffespan.
The total length of expansion/shrinkage in a "row" of cells, arranged face to face, varies according to the number of cells in the row. If you build a 16-cell "52 volt" battery pack as a single row, it the total length will vary twice as much as two rows of 8 cells. In previous calculations, I found that it was is impossible to build a 16-cell "row assembly" which could meet the requirements (12 PSI minimum, the previous maximum value was only 24 PSI) unless the end plates for the row were allowed to move - under the control of spring loaded bars. Maybe you could get by in a different way (less variance in SOC, tighter temperature control, or a "flexing" outer case. But I couldn't invent such as assembly at low cost involving only a few packs.
My last design is at ricks-recommended-compression-containment-for-eve-cells-LF280k-LF304), but that pack included only 4 cells (12.8 volts, for RV use). I am about to build a pair of 16 cell packs, supporting backup and grid-feed time-shifting via an All-In-One Inverter unit for my home solar system. I can use the exact same plates and crossbars when I build these, but Il will need much longer springs - tightened down to provide the the same minimum force (about 175 lbs each), but providing a lot more room for to handle cell expansion without "bottoming out", and also without adding too much more force from an excessive spring "rate" of additional force per inch.
Can you "get by" without creating compression in your pack assembly AND ALSO meeting EVE's other requirements for temperature and maximum charge/discharge rates? Yes, but your cell lifespan won't reach EVE's specifications. YMMV, depending on lots of factors. (Temperatures matter. And, At high and low SOC, EVE requires lower charge rates -- and I don't know of very many charge controllers which can respect those rules.)
