Bingo! That is my interpretation as well. EVE now seems to specify a static force at ~30% SOC and don't worry about the increased force as SOC increases. I built my box with Poron foam before that came to light. I would just make a rigid case if I were doing it again today.
One way to do this might be: Stack the cells as you would have them in your case (separators, etc.) in a vertical stack, then stack 660 pounds minus half the mean weight of the stack on top (about 100 pounds per 16 cells). Next, carefully measure the height of the stack at each corner. Use the mean value of the distances to build a box with that internal size. Now you either clamp the whole thing together to bolt it, or you use studs on your frame and pull the end plate together with nuts (using a tightening pattern similar to car head bolts).
The great part about this is that only one person needs to carefully measure a stack and share the measurements. If you have the same cells, your answer should be the same.
The bottom line is exactly like
@off.the.grid said: Nobody worries about pressure in their cylindrical cells at all, yet they come to fisticuffs if you suggest that their prismatic cells should be treated differently.
I feel the 30% SOC figure is a safe bet, its good that EVE now specify this, thats near enough to the SOC i had when I clamped mine and I would not feel comfortable clamping the pack at near zero SOC.
It makes me wonder if the commercial enclosures were designed with this method in mind, but I see that the separators vary in thickness, so would need to specify what thickness to go with etc with that method.
There are a few things I would do differently next time, firstly I wish I clamped all my cells prior to top balancing, but I also would have gone with a more rigid material for the clamps.
I was originally going to go with this stuff here, its pretty damn strong and rigid.
Phenolic Cotton Cloth Laminated Sheets Electrotechnical sheet textolite or Phenolic Cotton Cloth Laminated Sheets is a laminated material made by hot pressing of cotton cloths impregnated with a thermosetting phenol-formaldehyde-based binder.Due t
www.gteek.com
I ended up using a thick plastic material that has shown some deformation after charging, I dont know if its a big deal in the scheme of things, but its still keeping deformation to a minimum and doesnt appear to be getting any worse with each charge cycle.
My only real concern is the possibility that bolt tension is not evenly distributed, largely because the slight bulging after the top balance affected the spacing and couldnt get all the bolts down evenly without the risk of overdoing it.
I might go around the bolts again at 30% SOC and see if any feel too tight or loose, etc.
My advice to any beginners starting out here is to use the most rigid material they can find, install the insulating fibreglass separators and carefully go round tightening each bolt just enough to keep the cells fom dropping out while lifting the pack by the clamping fixture.
Forget messaing around with foam and springs etc, we want to prevent anything that lets the cells expand to begin with.
This is what I ended up doing sans clamping prior to the top balance.
It starts to get too technical when you go down that rabbit hole of calculating force, bolt torque, etc and many torque wrenches dont go low enough to do what we are trying to achieve.
This might not be the most optimum for longevity, but its sure going to be better than not providing any fixture at all and is much safer than clamping cells too tight.
Restricting cell movement is much easier than correctly compressing cells and will give acceptable results.
