EVE 280Ah - 6 months later
upnorthandpersonal
Administrator
Staff member
Moderator
63° North, Finland
So after running my 32 EVE cells for the past 6 months I decided to pull my weakest cell and do a capacity test. Tester used was a CBA IV, at 20A discharge (can not really do a .2C test right now). Result:
Ignore the bump at the 50Ah mark, I tightened the nuts better around that time - but this doesn't make a difference for the capacity test (see this video).
So my weakest cell after 6 months of pretty heavy use (do not know the exact cycle count) comes in at 274Ah. I can probably still squeeze another Ah or two extra out of it.
Just curious:
Are you running start Series Packs or do you have paralleled cells ?
Did you Top Balance or Bottom to Top balance prior to installation ?
The above noted Cell, is it a "Runner" ? or a Lazy ? You say "weakest" so I am assuming the Lazy one in the gang.
No paralleled cells: just two times 16s packs in parallel, with both packs having individual BMS (i.e., every cell is monitored).
I did a top balance before assembling the packs. The 'weakest' cell is the lazy/runner one in the bunch; it tends to get both highest and lowest first.
That is reassuring info to have presented. (y)
Do you know what the capacity of that cell was when you received it?
I love when people take the time to revisit their purchases / experiences over time!
All these capacity tests people do are great, but when it comes to proving the claims regarding # of cycles, that's an entirely different challenge all together!
I mean, if you're paying xy% more for a battery expecting 3x cycles, then it's important to know if you're getting your $$$ worth!
Hi, please what is your current experience with your eve cells, its almost a year now, are they still pulling a decent capacity? Also can you estimate like how many circles you may have done? Thanks in advance for your response
I'm planning a 48v system, would you mind sharing any pics and also the BMS part numbers you have been using for this?
THX!
Well, it's only about 3 months since I posted this graph, so not much changes since then. I really don't know how many cycles I did since I did not monitor this in detail - it's not very easy to do since you usually don't do full cycles at all. The cells still hold up fine and I expect them to do so for many years to come. When I add another 32 this year, it'll probably be even longer...
THX!
It's on the forum here in several threads, here:
A picture of the cells with my flexible bus bars is all the way at the end of that thread.
The BMS is a Heltec (JK) BMS. There are several threads on this one on this forum as well.
