Tball
- Mar 30, 2020
- 140
That's the plan once I completed the capacity test. I was seeing if anybody did anything different for just this approach to safely squeeze every bit of Ah out of our batteries for the test. Once the battery is completed and in the system my inverter will be setup to safely shutdown before the BMS has to.You want your loads to shut down before the BMS. Do something like telling your inverter to stop at 12v, and the BMS to disconnect at 11.6v. It really depends on how you want to run your assembled battery. The BMS should only trigger if all else fails.
Thanks!
