Alkaline
Solar Wizard
OP did you contact 18650 what did they say?
My problem with your tests, how do you know your equipment is accurate to the margin you're trying to test to?
What makes you think your setup is capable of doing 100% accurate tests and that you are doing the tests properly?
You will have a tough time keeping them in balance if you run a near full discharge, more than about 230 AH DoD. Absolute max discharge will be limited to ballpark of 280 AH, after which you will need to do some significant rebalancing. Only as strong as weakest link. Greater load current may make things worse.
You have two really poor cells from the data you attached, 304.1 and 303. Only 305 comes close to looking like a 304 AH cell.
Also sent them the link to this thread.I sent them an email, will try to call tomorrow, but if I have to pay to ship back and get a 20% restocking fee I'm just not going to bother and just take the loss and move.
I'm planning on buying 64 cells for a large 48v bank, I also have luyuan 304 matched and batched genuine on order 4 to try out.
I dunno. It would seem like accurate testing would require overcharge and then going down to below comfort level.
And then look at the ending voltage.
How does the factory test them?
Hard lesson on the crap shoot of grade B cells. As Forest Gump said, 'Like a box of chocolates.'I sent them an email, will try to call tomorrow, but if I have to pay to ship back and get a 20% restocking fee I'm just not going to bother and just take the loss and move.
You mentioned earlier about one of the cells not being cycled enough and that capacity might increase with the number of cycles; can these be easy cycles or does the cell/cells need to sustain a certain charge/discharge rate for a certain length of time and number of cycles?Greater than 80% discharged.,
I gave a couple of possible reasons for cell 303 discharge curve, one of which was possible improvement with cycling. More likely is the anode was manufactured with thinner graphite paste printing yielding lower anode capacity.You mentioned earlier about one of the cells not being cycled enough and that capacity might increase with the number of cycles; can these be easy cycles or does the cell/cells need to sustain a certain charge/discharge rate for a certain length of time and number of cycles?
No, as per standard testing for LiFePO4: charge to 3.65V and saturate (tail current), discharge until the voltage drops to 2.5V. Discharge rate:
AH calculations accuracy relies on accurate current measurements and accurate sample time increments. WH accuracy also needs accurate voltage increments measurements.What if my load tester is off by .1 amps or there is outside interference or only discharge to 2.51 volts etc.
0.1 amps error in 30 amp discharge is 0.1A / 30 A = 0.33% error, not significant.What if my load tester is off by .1 amps or there is outside interference or only discharge to 2.51 volts etc.
At least they are telling you it is grade B.Well seems like the old adage of coin toss with grade B is still at play here, too bad I thought 18650 had cracked the code, but looks like they are subject to the same realities as the rest.
Good for them for disclosing these are grade B upfront, however, guaranteeing pulling rated capacity is going to probably cause them more problems. Maybe they were good when tested in China, but by the time they arrived here not so good.
Either way, OP I see you are in Austin, I'm about 500 miles from you, I have the zke-40 as well so If you want me to test these for you and can meet half way or something I will be glad to compare.
As for me, grade A Rupi 280s it will be when I'm ready to build a pack for a 48v system.
0.2 to 0.4 C(A) is a good range with reasonable load test on cell.Well I'm actually more concerned about capacity tests, seems to be this is not the tell-all of cell. So a .2C discharge is going to be what should be done at a minimum.
