Hi All,
I have complete my DIY RV Lifepo4 build. I have watch many videos and research quite a few DIY Solar forum posts. But I have not been able to locate a comprehensive guide to required configurations for the Daly BMS and The Triron Epever charge controller. I thought I understood what all the parameter mean, but not sure anymore as I do get some errors which I was able to resolve following the parameter rules in the manual. Hope someone with experience can help with appropriate settings. (I left a space for your expert recommendations). I did top balance with cells in parallel on the bench.
Component Details:
Some parameters came from this post: https://diysolarforum.com/threads/n...sting-a-daly-clone-bms-smart-24v-100ah.35396/
EPEVER Charge Controller
There are parameter rules you need to adhere to from the manual. E.g. HVD > charge limit by 0.2V.
Questions/Comments:
Component Details:
- 4x Eve 304Ah Lifepo4’s in series
- DALY smart BMS 200 amp with Bluetooth
- 40 AMP Triron 4210N EPEVER charge controller
- 400 Watt of solar panels
- 2200(4400 Surge) Watt Giandel Inverter (it was a bit expensive, but it starts and runs my AC. Awesome!)
Parameter | Current Setting | DIY Solar Suggestions | Comments |
Cell volt high protect | 3.64V | ||
Cell volt low protect | 2.52V | ||
Sum volt high protect | 14.6V | ||
Sum volt low protect | 10.4V | ||
Diff Volt protection | 0.8V | What does this mean? | |
Chg overcurrent protect | 100A | ||
Dischg overcurrent protect | 180A | ||
Type of Battery | LFP/LifePO4 | ||
Rated Capacity | 304Ah | ||
Cell reference Volts | 3.2V | ||
Sleep waiting time | 3600s | What does this mean? | |
SOC Set | n/a | ||
Balanced open start Volts | 3.3V | Given how Daly balances, seem it needs time before full to balance, therefore start at lower voltage or SOC. Pls confirm | |
Balance open diff volts | 0.02V | ||
Chg high temp protect | 60C | ||
Chg low temp protect | 1C | ||
disChg high temp protect | 60C | ||
disChg low temp protect | -30C | ||
Diff temp protect | 15C | What does this mean? | |
MOS temp protect | 47C | What does this mean? | |
Temp charge protect | 0C | Default |
Battery Capacity | 304Ah | ||
High Voltage Disconnect | 14.8V | ||
Charging Limit | 14.6V | ||
Over Voltage Reconnect | 14.6V | ||
Equalization Charge | 14.6V | ||
Boost Charge | 14.6V | ||
Float Charge | 13.8V | ||
Boost Reconnect | 13.2V | ||
Low Voltage Reconnect | 12.6V | ||
Under Voltage Recover | 12.2V | ||
Under Voltage Warning | 12V | ||
Low Voltage Disconnect | 10.4V | ||
Discharge Limit | 10.2V | ||
Equalization Duration | 120 Min | ||
Boost Duration | 120 Min |
Questions/Comments:
- Some questions are embedded in the tables.
- What are the correct settings for the BMS and Charge controller?
- What I have is working, but does not make sense to me as, HVD should be at 14.6V(to protect the battery) but that would mean charge voltage would need to be 14.4V.
- Recommendation is to run SOC between 10-90%. How do you do this? Should it be configured at the BMS or Charge Controller or both?
- Do you have a recommendation for a heating pad? Still to be added. Pls include a link.
- The BMS has no fan L. I have driller hole in enclosure to help vent, should I add a fan? (already have 2 temp control boards)
- Is there a link for Daly BMS manual? Only have a 1 page connection sheet
- In the short term, I plan on disconnecting the vehicle charge wire, so I don’t kill the truck alternator. At some point I would what a DC-DC converter, any recommendations for a variety of amps and costs?
- My shore power charge is set to 14.6Volt and max 30Amp, current reduces to zero at battery gets close. Not sure if this is charger or the BMS that stops the charging. I think it is the BMS.
