Edited to hopefully make more sense.
Hello everyone. I’ve been reading many various posts on here for a few months in trying to learn about building and maintaining Lifepo4 battery cells but this is my first post about anything.
Last October 2022, I bought 8 ‘Eve LF280K’ supposedly A grade (-doubtful?) from ‘Amy Zheng’ at Docan Power. The transaction went well with fast shipping and fast email replies.
I did a good top balance on the cells and configured them as 12V 2P-4S configuration installing them inside an insulated box in my 5th wheel RV using one 200A JBD bms. Prior to the LF280K cells, I’d been using Trojan T-105’s for the last 7 years.
I’m having some problems now after 2 charges with the new 280 cells that I’d like to get some thoughts on from anyone that may be some help in figuring out what’s going on.
The first full charge was up to 14.2 volts, then absorb for two hrs. using a Victron IP22 charger, then I discharged to 10.6V then back to about a 60% SOC to sit. (FWIW, the batteries are in a box in the RV which is stored inside my shop and the battery bank is a constant 55-60 degs. F day and night).
A few weeks after that first full charge, I decided to do another charge on the bank for the heck of it and noticed a high mv spread starting at mid 13 volts. The spread went up to 326mv at 14.0 total bank volts. I stopped the charge there because it was increasing fast and I could see that it was going to hit the HVD so just stopped it.
Stopping the charge at bank voltage of 14.0-14.1V, #1 and #3 cells were low in voltage, just over 3.0V. #2 was roughly 3.6 and #4 was up to about 3.41-3.42V when stopped. It was definitely heading for HVD showing 326mv and moving up fast. I had the balancing set to start at 3.42V but there’s obviously no way it could possibly do anything as fast as the spread was climbing and as big as it was.
I moved some cells around in the bank a couple times and tried charging again but now I get a HVD (set at 13.6V) on cell #4 before the other cells get barely over 3V. I moved the charged voltage down to 13.8V but am having the same problem and it gets worse each attempt.
I’ve changed charger current between 15A and 30A on the IP22 and 18A from solar panels mounted outside the shop but of course all have same results.
I bought an internal resistance tester and checked the cells yesterday, I see 38, 38, 39, 42 and 62, 64, 65, 67 milliohm, the last 4 seems very high considering the specs. sheet show 19 milliohm?
I’m currently doing another top balance now using the 4 lower ir cells to then try using those 4 in a 4s configuration to see what happens, then do the same with the 4 high ir cells.
I’ve sent an email to Amy at Docan Power but I’ve got no response of any kind. I’m thinking since I’m not buying now but asking about a possible problem, I most likely won’t get a response. -I apologize for the length of this.
Any thoughts on what’s happening here?
Thanks, D. Walker
