Yes type 66 in 2021! (maybe 2021)
To further confuse the date code issue, I just got done reading this thread
Right but what I was getting at is if all the cells come with 291ah's capacity, and are run through a few cycles, will the capacity of the cells remain relatively close to each other? I know the capacity of all the cells will drop some. I didn't capacity test all of my 8 cells. My weakest cell...
diysolarforum.com
where Amy says, well, the date code isn't really the date code. But rather a start of production 'ish code.
Overall I'm sort of satisfied with the 66 versus 71 versus 76 explanations. My take away is it is probably okay to mix type 66 and 71 within the same pack. They're close enough to the same battery it will be fine. I'm not faced with that, but it is all interesting. Not sure about 76.
By the way, the date code of ACx interpreted as hex, indeed fits December. Hex numbers count as follows:
0..9 is 0 through 9, then A is 10, B is 11, C is 12, ... and so on till F is 15. That's base 16, or hex.
So B32 might well be March 2021. But I'm not sure if we really know.
