This chart is the garage water tank temperature. It is worth noting that the tank typically
starts heating by 8am indicating that excess power is being diverted. Long dips are the overnight
heat loss and deep narrow dips are from laundry water use, sometimes twice in the morning. Highest
temps are around 130F where the upper element shuts off. In five days of use the temperature never
drops below 90F. The garage water heater has the lowest priority of energy use after the house tanks.
Tank water is fed into the cold water inlet of the washing machine so all cycles use more hot water
than a normal home machine. Super +++ The soap dispenser at camp stays spotless. At my home machine
the dispenser has to be cleaned periodically. I've even done internal cleaning because of mold buildup.
If you have one of these machines, consider a blend valve to make the the cold water inlet hotter.
And this is what you do with excess power. I love getting free hot water! Typical diversion to this
tank is only about 100W to 460W. When it is all day, 2KW is overkill and a misuse of equipment resources.
No special heating elements were used. Just the two 5,500W 240V elements that came with the tank in parallel.
How I read the chart is the first day there were two laundry loads. Second day was one load that was
interrupted. Forgot to put soap in and it was restarted. Or a cloud came over and the washer stopped and
I didn't notice. The washer strictly runs off array power, no battery backup. When a big cloud comes it stops.
The next day no laundry. The t two wags at the top are the upper element thermostat turning off. The next
day was another load of laundry. With no washing the prior day the tank was evenly up to temperature with
no temperature stratification. Good data in needed to understand what is happening. These temperature data
recorders are awesome
