I am in the process of expanding my system to add more batteries and a smart shunt. I have a few questions, just to make sure I'm doing this right.
Current system:
My questions:
Lastly, I am also adding a BMS but will post separately on that. A whole other kettle of fish there and didn't want to confuse the post.
Appreciate the help.
Current system:
- 3000w Victron Quattro inverter/charger (6000 w peak)
- 1 x 16s chevy volt battery module (don't worry - in a fire safe cabinet
- Each cell group is 3.7v nominal.
- Each module is 3.7v x 16 = 59.2v nominal
- charging from a 7000w Honda generator
- adding 3 more chevy volt batteries for a total of 4 = 3.1 kwh x 4 = 12.4 kwh
- adding a Victron Lynx distributor in the battery cabinet
- adding a battery switch to the battery cabinet (mounted on the outside)
- adding a BMV 712 Shunt
My questions:
- What fuse sizes for the Victron Lynx? 4 x 100amp? Would increase fuse size when adding a 2nd Quattro
- What wiring size? Online calculators say 1/0 if I don't want to rewire when adding the 2nd Quattro
- Should I add another fuse between the Victron Lynx and the Inverter?
- Any suggestions for the battery shutoff switch? I was looking at the Victron Battery Switch, but max voltage is 48v
