Solarfun4jim
Solar seduced :-)
If you had two identical setups, using the same pv panel input and same SCC's, but you set one up to charge at 3.65v/cell and the other to charge at 3.4v/cell, but both had their charges terminated by a BMS exactly when their respective first cell hit of 3.4v, what would be the expected difference in SOC up to that point.
(note: not saying it is good practice to use a bms to terminate like this, but for the sake of experimental outcome).
Would both SOC's be very similar, or would you expect the one charging at 3.65V to be somewhat significantly higher?
