I'm on plan "C" for the location of my solar components (SCC, fuses, batteries, BMS, etc) in my RV. The new area is under a closet. If you don't know the components are there, you wouldn't think to look for them there. A wide drawer has to be pulled out to access the area and even then it's not easy to get to.
Instead of using a combiner/junction/breaker box I was thinking of mounting a DIN rail on the plywood mounting board and then breakers on the rail. Nothing would enclose breakers. There simply isn't much room for a real combiner box.
Good idea? Bad idea?
This picture shows part of the space. The plywood mounting board would go on the wall. I don't use the drawer for much and have considered removing the drawer hardware and taking the face off the drawer and turning it into a dummy drawer.
