berksrunner
- Jul 27, 2020
- 121
Hi Folks, I have a self-converted promaster van which has 900W of PV on the roof and 6.2 kwh (24v) of diy lifepo4 storage. The van goes through periods of non-use, and during those times, it makes no sense to rev the SOC to 95%+, particularly in hot weather; it does nothing but significantly shorten the overall cycle life. What I'd like to do is effectively limit the max SOC to somewhere around 70% when the van is not in use, and I'm trying to figure out the best way to do it (and it'd be nice if it was a way that could easily be disengaged when it comes time to use the van and then re-engaged once the van goes back into storage).
Here's a description of what I've got available to work with:
Smartsolar 150/70
BMV 702
Overkill Solar BMS (3x)
I've considered the relays built into both the BMV and the mppt, but I'm not sure exactly how to use them. I could also manually set a lower voltage (maybe around 26.3) on the mppt, or I could do something similar to the BMS's (but I'd need to do it 3 times since I have multiple).
Any thoughts? TIA!!
Smartsolar 150/70
BMV 702
Any thoughts? TIA!!
