Extending Daly Smart BMS temperature sensor?
Tasemu
Hi all, In my setup I am unable to easily get the temperature sensor on the cells for my battery. Does anyone know if it is possible to extend the temperature sensor using wires, or will this cause a change to the value?
Cheers!
Yes you can lengthen the sensors wire if needed. It will not affect the performance.
Try to use the same size wire.
I have done it without any problems. ✌️
Thanks mate! Do you happen to remember what wire size it is? I can wing it if not. :)
