sunshine_eggo
Happy Breffast!
the main feeder cables from the batts to the shunt / DC breaker and then back to the inverter are 16mm sq
the link cabel betwwen the two batts is a 70mm SQ
all crimped with a professianal crimp tool
are you thinking voltage drop? i can go and measure across the cables to see if there is anything significant?
Ensure proper torque. 16mm should be fine for the 20A you're pulling, but it would be a good idea to check for voltage drop.
The low set point seems to be set too high at 25.5. You may have cable and fuse/ breaker volt drops to also deal with.
Any DC breaker in the feed is suspect unless a quality item.
Try reducing to a lower value, 24.0 volts or even lower at 23.5 volts.
28.5 volts charge may be causing BMS protection to cut off the charge.
Mike
Agree with this. Wanted to check connections/cabling first before I mentioned it.
Your charger also appears to be like the Growatt that starts at low voltage and immediately terminates once high voltage has been achieved - no absorption. If that's the case, you should raise your charge voltage to 28.8V to make sure you're getting close to full charge.
