Harmony5000
- Feb 8, 2022
- 54
Hi all, researching wind deflectors for solar panels mounted on van roof. Have any of you found solutions you are happy with?
Also in my research it has been mentioned a 1” gap between panels is recommended to help heat beneath panels escape. I think that might be suggested for large home panel arrays? I wonder if there’s much of a difference for just the few you’d put on the top of a vehicle. I’ll be installing 6.
There is nothing on the market that looks really good as far as off the shelf products so will be building them. I’ll try to keep this updated after install.
If anyone feels completely safe driving at highway speeds without a deflector I did just read a report on another forum where a member was driving through Utah and their front panel completely ripped through the aluminum framing and smashed to bits. The z brackets remained intact attached to the roof.
As far as easy solutions - someone said simply putting a noodle like the big foam water toy on the front panel helps. That might just be with noise not sure. Seems like the frame beneath each panel can easily grab air.
Other solutions I read involve cutting cardboard to fit the top of the vehicle >to> the first panel then taking that to a metal shop (sheet metal) or place to cut plexiglass basically using it as a stencil.
Someone also mention after the deflector there is negative air pressure above the first panel (pushing down upon the first panel) which can also be a problem if I read it right. But idk? I think I’d rather have them push down to the vehicle the fly up over and smash like the story mentioned.
Thoughts?
Thoughts?
