Hi, Will (and others)! Thank you, Will, for your recent review of the Bluetti AC200MAX (see
). Although I really like all the features of this sogen, the ventilation fans on my AC200MAX are noticeably audible. Comparatively, the powered fans within both of my AC300 units are extremely quiet when running – no detectible motor or bearing noise; only air movement is slightly heard. Using a decibel measuring device, I measured ~48.2 dBA for the “low speed” (single fan?) noise level, and ~57.9 dBA for the “high speed” (both fans?) noise level, all at 1 meter away from the AC200MAX. Based on my measurements, would you consider the fan noise level of my AC200MAX essentially “normal” for this model sogen, or does it seem too loud, and should I have Bluetti technical support do an inspection/evaluation?
