Stormsoul
- Jul 4, 2021
- 43
Had power outage today around noon after a couple days post config Having no issues. R n. 50% themLooked it up and its a CAN issue. Powered all off and back on and things are fine. I thought i had communication set up correctly for two inverters as far as the red and black wire is concerned. also when battery is getting charged i think it is making it to a little over 50% and kicking off grid assist and using battery and solar. Its in SGU setting so not sure what else to check for these two errors. Batt are user defined and in default settings.
seplos 280ah cells diy mason lifepo4 kits X2.
any help is appreciated. Let me know what other setting info is needed. Been working new setup issues in another thread and moved this issue to a new thread.
