Hello all. I have been restoring an old yacht in Brisbane QLD Aust. for many years. Part of the retore was to re popwer the yacht with a more reliable off grid energy system.
just under 2 years ago I purchased 8 cells from the not so reputable OYE store on Aliexpress. I have built two working 12V 280Ah 4S batteries controlled by a Dalygreen 250amp Smart BMS. All cells where top balanced as advised by Will and assembled and load tested to the required ratings. Amazingly they worked and the ratings came out at the advertised rate of 280AH +-5. I carried out 5 repeated tests and was consistent with the cells balancing and load repeatability. I assembled the units and stored them on the shelf in a 70%SOC in a storage shed until I needed to install into the yacht. Due to health issues this has been 1 year longer than expected while I recovered. Just recently I checked both batteries and found one still at 70% but the other wouldn't turn on. After checking the cells I found one out of the 4 cells dead measuring 0V and 0.3 mohm while all other cells measuring 3.35v 0.65-0.70 mohm. The cell will not recharge using two separate dedicated Lifepo4 cell chargers. One a dedicated 15amp Lifepo4 3.65volt single cell WATE smart charger, the other a ISDT Q8 Max 30amp 8 cell Smart Battery charger. On the latter charger the unit trips after 5 seconds with an over current warning alarm.
Is there any technique I can use to recover this cell or will I need to replace it. I have tested the BMS fully functional with the other set of batteries so do not suspect a BMS failure but of a bad cell.
Please note the Oye Store company have given me the run around and refuse to replace the faulty unit under warranty as it is outside the 12month period even though I have not really used the unit. I have also tried to contact nikkie@lightnening-power.cn for support which is the address on the label on the battery but so far no response.
If I cant recover the cell then If someone lives in QLD and has a spare cell from other bad batches from these shonky sellers that they can sell me for a reasonable price I would appreciate it as at this stage I cant afford to buy another cell from the OYE store at $288 for one cell. Attached are the photos of the faulty cell and QR code and a picture of my completed batteries ready for install into the boat.
Thank you for your time any possible help.
Regards Charles
Regards Charles
