Feedback on my system design
MatWill
Hi Guys,
I put an order in for the new SOK 206 with heater arriving in June (EU) and i am planning a system based on what I have currently, can anyone give feedback on it?
The solar panels are 55w sunbeams each connected to its own mppt which charge the lithium, main loads will feed the starter with a dc to dc charger charging the lithium.
One thing I noticed is the Orion is only 30 amps but SOK recommend charging at 40 amps
Thanks
Mat
60 amp fuse is a bit high for #10 wire. Maybe 40amp fuse or #8 wire (or both).
The SOK should have a main fuse to the house loads and possibly to the controller(s)
Are you sure two controllers are needed? If the panels are same they can probably run series or parallel to a single controller.
