andrewl04
I am close to finalizing my plans for my travel trailer. This will be my first full install so I want to check myself. I have tried to incorporate all the best practices I have seen on this forum. Thanks in advance for your feedback.
I have attached my plans as a PDF. (Happy to share the .drawio file once revised/complete if anyone wants. I was hesitant to share since it is an 11MB file)
A few specific areas I wanted to check; letters below correlate to the lettered circles on the diagram:
b/g. I was considering using DIN mounted mini breakers for PV and shore power protection. Any feedback over flat mounted ones?
c/j. Confirming PV and battery shunts on positive wires per Electrodacus spec?
d. Do I need a SSR to allow the Electrodacus SBMS0 to isolate the PV input from the Growatt 24v SPF 3000TL LVM?
e. Confirming SBMS0 to control the Growatt inverter by wiring into the Growatt's switch?
f. Confirming the need for a SSR to allow the SBMS0 to control shore power isolation by only isolating the line (not neutral) of the AC circuit?
u. I have seen some posts about using a AC GFI breaker between the inverter output and my main panel [f] to reduce the risk of AC somehow making a circuit via the trailer frame/etc. Needed? Any feedback?
General question: Am I fused at all the right locations? Anything I don't need? Feedback on the amps I calculated?
Thanks!
Thanks!
