wmsolarconsultant
That isn't RS485 That's rs232, totally different even says on the adapter you took a photo of.
Wrong cableWhat's a pinout?
Are the converter rs 485?What's a pinout?
May you send a photo of the correct cable, adapter and instructions?Wrong cable
The manual has the diagram, I understand that. I am asking for the cable and adapter, a link to buy the correct one. It's no use having the diagram if I don't have the cable and adapter, that's what I ask for.Battery manual and inverter manual. You have them, right ?
Yes I got also the adapter from rs232 to rs485 and discarded the provided cable with the battery.That isn't RS485 That's rs232, totally different even says on the adapter you took a photo of.
Thanks a lot for this, do you by any chance have the Password?As this has now been posted to the forums and apparently they are no longer using it, here is a newer version.
If you fuck up your batteries, down to you !!!
more information ,voltage ,load ,hi i have a problem with my Felicity 24v 150Ah battery which communicates to a Felicity 3k inverter.. the problem that persists: the percentage rate normally drops to 54% then drops sharply to 20%View attachment 130920View attachment 130921%.. but while charging it does goes up in % gradually without problem .. what can be the cause? anyone encountered this?
plus d'informations, tension, charge
26.08v ; -7A ; load 3% ; power active 11w.
