felicity solar LPBF48200 10KWH 6 in parallel to a bus bar do i need the bms connected
Jefits
Temecula
I have bus bar with 6 felicity solar 10kwh. I can connect each bms together to be in "parallel". However the bus bar is connected to each battery individual with same length wire.
My question is: Is there any advantage to connected the bms together. What i am worried about that it just going add one more thing that could go wrong.
Hi, any luck with this particular situation ? I have a similar situation.
Question is :
I have two of Felicity LPBF48200-H bateries, and a pair (-) and (+) bus bars and one inverter MPPSolar LVX6048, can i connect both of each terminals to the bus bar correspondingly, two positive cables in the + bar and two negative cables in the - bar, and then connect another one as the 3rd cable from each bar - and + to the inverter?
Dip switches should be 1,5 in first battery and second battery 2,5 as well?
batteries are charged already.
Thank You
Hi,
I have been running the above config. with 1st battery on 1.0.0.0.0 and 2nd battery on 0.1.0.0.0 and LIC on my MPPSolar LVX6048.
The only thing im noticing is, that the batteries (including the former with 1year use that reached 56.7V before when charging) are not longer reaching over 54.2V 54.4V and stops charging there when for a while there. In the contrary, the apps are saying 56.x volts.
And when charging, batteries says different from what the APPS shows., the APPs, shows around 1--3 >= than the batteries shows, depends where they are in % report.
Does that means anything ? Second battery just got here bran new from Felicity Power in GA, the previous Battery is running about a year, where purchassed new as well from local dealer.
Hope this helps.
Thank You
