Ferruel Crimping Sizes
aKO
Just bought an inexpensive crimper , never needed one before but i have some connections that might benefit from having Ferrules . Can someone advise how to select the correct adjuster when its supposed to be self adjusting . Had no instructions with it and nothing came up on Google to explain . I assume that you would select the smallest ferrule that the cable fits into but not sure about the 6 position adjuster wheel ? .
Having no idea of what brand/model crimper you have, here's a screenshot of the one I use. Each position of the die is marked with the wire size in mm^2 and a conversion table to AWG. I suspect yours probably covers the same range of sizes since most of that stuff comes out of the same Chinese factory.
I watched the Deye 5kW install video of EEVblog on Youtube.
He used the same battery lug crimper.
Set it one size smaller.
Use 2AWG setting for 0AWG
That is just to adjust how hardie presses. That will vary depending in how close the ferrule matches the wire.
This is the type of crimper
Yup, I probably have exactly that crimper - your problems are as mentioned in your other thread asking the same/similar question --- you need to extend the wires past the end of the ferrule and trim after ... the wires should totally fill the ferrule - if it doesn't then try the next size down or order a "true awg" type ferrule off ferrulesdirect.com -- they run more true to size.
the end result won't be as tight as a crimped lug that does a cold weld, but they will be tight.
And Victron explicitly states to use fine stranded wire and NOT to use ferrules in their MPPT --- if you do use a ferrule on a Victron MPPT you can expect the connection to get hot and possibly damage the terminal block ... and Victron will reject the warranty claim.
And one thing - on ferrulesdirect you can buy them at different lengths -- either measure the depth of the terminal block or look around here - several have reported it. I have a 250/100 and a 150/35 I can measure if yours is either series.
Victron's 'Wiring Unlimited' guide Section 4.3 'Cable Connections' now has a section on Ferrules, they say use them everywhere if you feel like it, just ensure they are fitted correctly. Definitely use them on screw terminals where stranded wire is being used, definitely don't use them on solid core wire.
Victron's MPPT manuals explicitly forbid the use of ferrules and it will void the warranty if there is any sort of heat damage on the terminal connections. This is because their terminals have interlocking cup shaped teeth to gather and compress loose wires in for a good connection. A ferrule will not let them work correctly.
Do what you want yourself, but giving advice against the mfg manual for a product isn't good.
I'm looking at the Rev.09 02/2025 manual online for my 250/60 charge controllers and there's no mention of not using ferrules in there either.
It does mention the Wiring Unlimited book I referenced earlier though.
8.8.4. PV connections burned or melted
Burned or melted PV cables or connections are not covered under warranty. This can occur due to the following reasons:
• Loose screw connections.
• Using cables with rigid core wire or rigid strands.
• Soldering the core wire ends of the cables.
• Using thin cables may result in higher currents when the PV voltage is lower. Refer to the Wiring Unlimited book for more
information.
• Inserting cable insulation too deeply into the connector.
• Exceeding 30A per MC4 connector pair.
• Incorrectly crimping MC4 connectors.
• Using low-quality MC4 connectors.
Apparently updated in Aug 2024 - the stress is on gas tight crimp on the ferrule as well as inserting to full depth. This means the right length ferrule and using a crimper on the ferrule that makes it gas tight prior to insertion... so proper size ferrule, proper length ferrule, real ferrule crimpers of the right size and shape or hydraulic crimpers.... Just getting it straight in my head.
Yer right, I'm wrong.... it happens.
Updated my info post on ferrules
