John Frum
Tell me your problems
- Nov 30, 2019
- 15,224
A good number of people on the forums are interested in bms's that are not fet based or not in the current path.
I wonder how efficient a fet based bms is at passing current.
Here is my idea off the top of my head for a test bed.
hook up the bms balance leads to a balanced battery that is not in the current path.
Hook up the b- and p- and a shunt in the current path of a very beefy battery charger.
Pass current through a test load.
Measure the heat produced by the BMS with an IR camera.
Measure the current and voltage via the shunt.
No heat, no loss; right?
I would guess some math could be done to compute the efficiency from the heat generated.
