Final big shipment'o stuff arrived
pvdude
Florida
Solar panels arrived!!!
12 REC 365 watt, will connect in series.
But first, need to build the PV mounting system.
Steel pipe was delivered, and most of the pipe connecting brackets showed up w/ the PV order.
I dragged out the 1950’s vintage concrete mixer.
Need to obtain a pallet of bags of concrete mix.
My back already hurts, just thinking about pouring the piers.
Hoping giant son will drive over to help.
That is really interesting material, I had no idea such a thing existed!
I think part of the reason the PV mounting system requires such massive & heavy concrete
piers is to keep it from launching into the air in high winds.
The assembled array has the aerodynamic characteristics of an aircraft wing!
The piers are 12” in diameter, fronts are 30 inches deep, rears are 58 inches.
That is 1800 lbs. of concrete, supposed to keep the array in place in 120 mph wind,
which is what we get here when the hurricanes visit.
Should power your Alpha amps nicely!
The only problems I have heard of with the foam cement is that if your water table rises above bottom of the foam it can displace posts out of the ground.
My last set of fence posts went in great using expanding foam instead of concrete. And no chiropractor.
https://www.homedepot.com/p/Sika-33-fl-oz-Fence-Post-Mix-7116170/300934597
Has held up very well including opening and closing the gate. With a narrow hole (6") you can easily get two posts per bag.
From working with the engineers on quite a few sets of plans for ground mount systems, @pvdude has it exactly right. The concrete is there to provide a weight, almost like a ballast. The concrete is not "gluing" the racking to the ground moreso than weighing things down. If for example, you upgraded from a 2" pipe to a 3" pipe, to increase how far apart your piers are, now you need to increase the hole size and depth to maintain a similar "weight" of concrete.
Ground screws, however, are a totally different animal.
This is so interesting.. I had 12 REC 365AA panels delivered 3 weeks ago myself! (Well, they were NOT the alpha black panels I ordered). This has been an interesting problem from that point and still is. I will elaborate on this more later... Did you happen to get yours from Solaris by chance? Just curious. Excited to see your results! Thanks for sharing!
