D
Deleted member 1888
Guest
So im in the final planing for my system and i have a few more things I need to figure out(All on the AC side only). My RV/cabin will be 100ft from the solar panels as that is the only space I can use for them. My plan is(tell me if there is a better way) is to have my solar shed next to the panels. Inside the shed will be the controller,batteries, and inverter all very close together. Then the inverter will send the AC power 100ft away to the breaker box at the RV(will install the box myself).
When I use this calculator http://wiresizecalculator.net it tells me the only way to get the 15000watts of power I want is to go 240v. As 120v needs 125 amps to carry it and the wire is something called 300 Kcmil(I cant even find this). So if I use 240v how do I wire this and what wire do I buy? The site only tells me I need 1 awg to carry 240v 100ft at 63 amps. Is this all correct? If so what wire will I need to buy? normal welding cable?
Can WIll make a vid on how to wire up the AC side of an inverter?
