I didn't really bring it up much, except in other threads because I didn't want it to be "Normal Operation" and me be upset about it.
I am running it close to max, very often, and another 12k would help, but only because they would then run at a lower output. The fix shouldn't be spend another $6k+, it should work within its operating parameters.
To explain what actually happens, here is a graph from Solar Assistant. Anytime there is large DC current going in-or-out of the battery, the temperature spikes. So between 10am and 3pm, the PV is charging the batteries, and there is high DC Current going into the battery, with the occasional drop in temps because the house load increased, which forced PV direct to AC loads. Then you can see at 4pm, I started selling back to the grid at max output (9000w), which causes the temps to peak and stay there until 9pm, when the load turns off and the house is in pretty much standby while we sleep.
You can see there is a slight lull between 4pm and roughly 5:30pm because there is still PV available, so it is taking PV and sending to the grid, and then supplementing the rest with battery to sellback with the full 9000w. Since it is not full output from the battery, the temps don't rise as high. Since noticing this, I have it set to only sell back to the grid at 7500w, which keeps the temps at 82-85*C, below the derating limit. This is a band-aid, but I'm not getting the advertised capacity from my very expensive inverter.
Mine is an outdoor model, you have linked an Indoor model, and it is an outdated manual.
This is the one direct from their website:
A firmware update has made both of these values 9000w, as well as 12,000w with PV available to supplement.
I am trying to use the full 9000w between 4pm and 9pm, as well as charge with max current while PV is available.
The updated manual shows the same. But yeah, the garage is at 78*F. Well below the temp ratings.
