Many portable power stations offer higher maximum wattage MPPT solar charging than through AC bricks or cigarette lighter inputs. Sometimes as high as triple the watts and therefore much shorter charge times.
Just when I think it has been concluded one shouldn’t use MPPT input directly from a non-solar source I watch what Will does at four minutes in the video below (he connects a 30 volt desk input to the MPPT to test the unit):
In the related video below Will also complimented the hack to boost the input/output voltage from a DC source. If one has a pretty consistent DC input from a running vehicle’s 12v battery, and adequate cables for amperage, is there a reason not to use the MPPT input in the way Will does above?
